Re: Moving 5x6 Bales with 300
Posted by rhtx55 on December 16, 2014 at 17:14:55 from (68.191.209.251):
In Reply to: Moving 5x6 Bales with 300 posted by VaGasman on December 16, 2014 at 04:59:33:
I would first try a set of 6788D front wheel weights, (42 1/2 pounds each) if that doesn't do it, you can add another set ( 2 weights per wheel) that bolt right on.
The frame weights that bolt on each side of the front bolster are really salty but they weigh 125 lb each.
362959R1 left hand,
362960R1 right hand.
I have seen some "custom" weight brackets made & used on F300 pullers that used the later IH suitcase weights out front.
This post was edited by rhtx55 at 17:18:27 12/16/14.
