Re: 686 Water Pump
Posted by Kevin Meier on December 16, 2014 at 19:46:50 from (208.90.10.9):
In Reply to: 686 Water Pump posted by jr1983 on December 15, 2014 at 17:02:14:
for the German diesels there are 2 different pumps. 3/4" shaft or 1" shaft on the hub. Other than that it shouldn't be a bad job. You shouldn't need to remove the water pump cast iron backplate. Just unholy the water pump .
