Years ago I spent a season running a Hesston 4790 3x4 baler behind a 135hp CaseIH 8910. When running for maximum capacity you could easily put the tractor on its knees but if you're not in a huge hurry 120hp would probably be enough. I often had a 3-bale accumulator on the back that put an additional load on the tractor; with only 120hp I would not recommend this attachment unless your fields are really flat and firm. To have your capacity be baler-limited instead of power-limited takes a good 160hp.
There isn't too much hydraulic load with these machines, just the pickup lift and the supply for the chamber tension system. The Hesstons can be configured for open- or closed-center systems and I assume other brands can be as well.
The tongue weight is substantial and in rough ground there is a lot of bouncing which can be hard on drawbars. I've seen some folks run a chain between the lift arms and under the drawbar to help carry the weight. I didn't have any kind of support on the 8910 drawbar and 10000+ bales later it was still straight so if you compare that bar's thickness and cantilever length it might give you something to reference your tractor against. (Won't tell you anything about the material strength but it might give you some idea at least.)
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
