200pinion gear on pto
Posted by dewy on December 17, 2014 at 15:18:03 from (72.145.224.35):
got jaw puller, removed broke pinion gear.pressed on new to me gear,put bolt back in...tryed spinning buy hand,feels like has tight spot... didnot feel like that with broke pinion...do you think i pressed on to far,,you can hear it hit housing sounds like...like its crooked..key way was true but grove wher key way sits was wollered ,,alittlebigger than keyway but groove in gear is tight.any suggestions....thanks dewy
  Upload Photo  Select Gallery Photo  Attach Serial No List
