Re: 200 pinion gear removal
Posted by mkirsch on December 18, 2014 at 05:02:59 from (72.45.143.81):
In Reply to: 200 pinion gear removal posted by dewy on December 17, 2014 at 03:49:29:
I learned to use a small hex nut underneath the point of the puller shaft. Portable centering hole.
