Re: Farmall H 12V Conversion
Posted by Ed Hotaling on December 18, 2014 at 19:51:03 from (67.240.55.230):
In Reply to: Farmall H 12V Conversion posted by grizzly-man on December 18, 2014 at 19:40:50:
You actually have a very easy tractor to convert. I did my '47 several years ago, All you need to do is switch out the charging system to match the battery and put in new light bulbs.
The question I have is why do you want to convert it? If you need to have it compatible with other equipment, that's one thing. If you are having trouble starting your tractor, you are better off going through the existing electrical system. I had a lot of trouble with mine even after I converted it. It turned out that the old battery cables were badly corroded inside the insulation. Had I started there, I would have kept it 6volt.
  Upload Photo  Select Gallery Photo  Attach Serial No List
