Re: farmall 200 pto shaft removal,new to me shaft is bent
Posted by haas on December 19, 2014 at 04:16:39 from (50.142.111.41):
In Reply to: farmall 200 pto shaft removal,new to me shaft is bent posted by dewy on December 18, 2014 at 15:40:21:
Fuzzy memory here, but as I recall it comes out to the rear (toward the outside of housing). Gear must come off the shaft first. Do not try to press shaft out through the gear as there is a woodruff key that will not clear. The key has to be removed from shaft before you can get the shaft out.
  Upload Photo  Select Gallery Photo  Attach Serial No List
