Are you going to remove the seal? I think the seal will keep the outside bearing from coming out. The inside bearing will stay in place since it has to come out to the inside. Depending on where your shaft is bent you may have troubles getting it out. If bent on the outside you should be ok. While you have it apart, might as well replace the seal. If the bearings do come out, simple matter to put them back.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
