Re: Super h engine valve lift
Posted by D Slater on December 19, 2014 at 19:38:43 from (184.14.166.249):
In Reply to: Re: Super h engine valve lift posted by David G on December 19, 2014 at 17:34:58:
If I figured correct the rocker ratio on some valves opening .370 on a .240 lobe lift is 1.62.
  Upload Photo  Select Gallery Photo  Attach Serial No List
