If there is way incorrect timing, and or valve timing is off a tooth, or the carb is dumping fuel in wildly, it could act like that. I believe (though you show poor compression) that it should run way better than it does. A worn engine can make fair power. A worn engine can run smooth. I would set the valve adjustment. then check the timing and distributor shaft wear. If all else seems perfect then I condemn the compression. What is the history of the issue. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
