Posted by Caterpillar guy on December 20, 2014 at 00:42:37 from (75.134.172.121):
In Reply to: IH 806 Standard posted by Lee A. Schexnaider on December 15, 2014 at 13:47:35:
There are 2 pumps 1 for the steering,TA,trans lub. The other is for the 3pt,and remotes out the back. The one for the 3pt is behind the left step. The other is inside behind the MCV bolted to the back of it. That is the block right in front of the left step. The filter is across from the rear pump in back of the right step. Take out the half dozen bolts or so and the filter is in that tear drop looking lid. There is a square o-ring and a screen make sure that screen is clean also. Report back with what you find.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
