Re: cub starter
Posted by Jim Becker on December 20, 2014 at 09:21:24 from (173.84.240.213):
In Reply to: cub starter posted by gene bender on December 20, 2014 at 07:51:16:
Quoting Removed, click Modern View to seeThat is the sort of misassembly I was thinking of. Both ends would have to be out of position for the through bolts to line up. They couldn't be far out of place or the through bolts would run into the field coils, but there is probably enough room for this sort of misalignment.
Quoting Removed, click Modern View to seeThat is the correct number for the early Cubs (long arm). The ones with the short arm on the switch were 1109611. The field coils are the only difference in the starters. Any combination of starter, switch and lever should fit with no interference.
