After the serial number on the metal ID plate look for letters.
S = it came set up with a T/A and IPTO drive. P = it came without T/A and with a IPTO drive. R = it came with a T/A and set up for transmission drive PTO.
If it has IPTO the PTO housing will have a vent, oil check and drain plugs and a long operating handle on the right. If the PTO just has a small rod to operate on and off its not IPTO.
On the T/A lots of parts can be stripped off, a T/A eliminate kit could be installed later or other things. If no external t/a operation parts are to be found look at the serial # suffix letters. If letters indicate a t/a, take the tin top cover off the center housing, 4 bolts. Then see if a t/a clutch is still there.
Remembered to say if it has no suffix letters like above or if it just has a letter or letters that are for other attachments. It would be built with no t/a and no IPTO.
This post was edited by D Slater at 20:17:15 12/20/14.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
