Re: Checking for battery draw with DVM
Posted by Owen Aaland on December 20, 2014 at 23:53:30 from (216.47.34.37):
In Reply to: Checking for battery draw with DVM posted by farmboy48 on December 20, 2014 at 14:16:51:
Assuming you are dealing with a 10SI alternator. if pulling the plug on the alternator cures the symptoms and changing the alternator with a known good did not, check the voltage on the #1 terminal. There should be about six volts with the key on and no voltage with the key off. There is no diode on the diesel tractors but there is a resistor. Power for the #1 terminal comes from the key switch through the resistor and then to the alternator.
If you tractor is an early model with a 10DN alternator there should be no voltage on either small terminal with the key off. With the key on there should be about six volts on the F terminal and no voltage on the R terminal. With the engine running the voltage will vary on the F terminal depending on alternator demand. The voltage on the R terminal when running should be about 6 -7 volts AC.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
