Re: Super h torques
Posted by Oregon Tractor Jack on December 22, 2014 at 14:34:27 from (50.137.138.152):
In Reply to: Super h torques posted by ajdeereman on December 21, 2014 at 17:32:48:
Since I am sitting right next to my H series repair manual I will look them up for you.
Cylinder head nut torque 73 foot pounds
You need to use the correct tightening sequence when doing this.
Funny, my book does not have a torque value for the rocker arm bolts. They are 3/8" so I would torque them to 18 to 24 ft-lbs.
I have a nut to stud torque of 53 ft-lbs which seems a bit high. Those are 7/16" bolts, so I would think 38 to 40 ft-lbs would be okay. The truly important torque is for the head nuts, the rest of them should be tight, but not screaming. Don't forget to re-torque the head after you have run the engine for awhile. I manual is a very important thing to have for any tractor.
  Upload Photo  Select Gallery Photo  Attach Serial No List
