Re: Farmall 400 missing
Posted by David G on December 22, 2014 at 17:28:56 from (204.12.184.93):
In Reply to: Re: Farmall 400 missing posted by Bill in IL on December 22, 2014 at 14:29:14:
You did not mention you changed plugs.
You could probably gain some performance if you advanced the timing 4 degrees. This will work unless you hand crank, which should be 0 initial, or a high compression engine which should have about 25 total.
  Upload Photo  Select Gallery Photo  Attach Serial No List
