Re: 706 backfire
Posted by wayne in MN on December 22, 2014 at 18:26:37 from (97.92.1.19):
In Reply to: 706 backfire posted by tvertiz on December 22, 2014 at 16:07:16:
Backfire through the carburetor should indicate a burned intake valve.
Remove the spark plug from the suspect cylinder, bring the piston up on compression and blow compressed air into spark plug hole. Have someone listen at the carburetor (air intake hose removed) for escaping air.
Buy a leak-down tester and learn how to use it. Great diagnosis tool.
  Upload Photo  Select Gallery Photo  Attach Serial No List
