djsamuraii said: (quoted from post at 21:06:39 12/16/14) Here are the photos of my rebuild project. I can't break the hub loose. I heard that there was a pin on the generator pulley. I found what I think people are talking about on other forums. On top of the pulley closest to the Bottom of the pump is a little silver smashed in piece of steel. Is this the pin I need to get out or does it take brute force to separate the hub to get to the bearings?? Please advise
Finally was able to take off the pulleys. You need to remove the center shaft bolt that has to round edges and two flat edges with a crescent wrench with the pump on the block. Seals and bearings came of with a vehicle dent puller from harbor freight. new bearings installed and new seals tapped in with a flat piece of wood and a heavy hammer. These pics have the pulleys before rebuild and the thermostat housing rebuilt.
This post was edited by djsamuraii at 07:40:50 12/23/14.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
