Re: Engine heater
Posted by mkirsch on December 24, 2014 at 04:58:52 from (72.45.143.81):
In Reply to: Engine heater posted by grumpydaniel on December 23, 2014 at 19:39:02:
I'm with caterpillar guy on this one. Heat isn't necessary on a gasoline tractor if you're running 10 weight oil. That said, it doesn't hurt anything except your electric bill.
Here's what a tank heater looks like, hopefully:
[img]http://media.external_link.com/is/image//TractorSupplyCompany/0191924?rect=0,0,480,480&scl=3.05&id=wXScj2[/img]
This is one from Tractor Supply. They sell two models, a 1000W and a 1500W.
You install a Tee on the temperature sensor port in the head, and then plumb this heater between the Tee and the block drain on the side of the block.
If you're going to do it, mount the heater somewhere tasteful please. Don't let it dangle or zip tie it to the closest protrusion.
