Posted by rustyfarmall on December 24, 2014 at 06:20:27 from (208.126.186.41):
In Reply to: Engine heater posted by grumpydaniel on December 23, 2014 at 19:39:02:
Pay a visit to your local auto parts store. NAPA, CarQuest, etc. They should have several tank type heaters to choose from, but your H will not require anything very big. It will install on the left side of the engine. Remove the engine block drain plug, install a fitting, clamp a hose to it, and the lower port on the heater goes to that hose. The upper port on the heater goes to where the temperature gauge is attached, on the right rear of the cylinder head. Remove the sensor unit, install a "TEE" fitting, and then the hose from the heater can be attached, as well as the temperature sending unit re-installed.
There are other ways to do it, but this is the method most often used around here.
A battery maintainer on that old H will also help ensure she starts when needed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
