Posted by DR. EVIL on December 24, 2014 at 13:56:47 from (70.194.170.147):
In Reply to: Re: Engine heater posted by mkirsch on December 24, 2014 at 04:59:19:
I've had a 750 or 850 watt tank heater on my Super H for 45 years. The faster cranking and quicker starting has saved wear and tear on the starter and batteries worth at least as much as what the electricity has cost, probably more like double.
If you install the temp gauge sender on a tee, you may as well not even install the gauge back on the engine, just hook the block heater up right where the temp sender was. The sender has to be in the flow of warm/hot water. Being stuck in a dead end of a tee it will not work.
Cat guy may have good luck putting his kerosene heater right against his cat for two minutes, but I wouldn't do that to an IH gas engine. I'd set it several feet away and even a 100,000 BTU heater would have to run at least a half hour burning $7/gal kerosene to make much difference. Makes the few cents of electricity look cheap doesn't it!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
