There are many mount systems shown in the archives. Some are on larger series tractors, but they are similar in that the belt alignment is key. The wiring diagram and installation pics are for a different tractor, but essentially the same. Hitachi 14231 is the #. The Hitachi is seriously easier to fit. The Use of 1/4" female insulated spade terminals works on the connections. The S terminal connects directly to the big terminal with a short wire, 14 gauge is OK. the L terminal connects to the ignition through a marker lamp (not LED style)or a 10 ohm 5 watt resistor, or a 3 amp diode with the band toward the alternator. It should get power from the ignition switch, full bat voltage. The big terminal attaches to the amp meter using 10 gauge wire. (reverse the leads on the amp meter, hook the battery up negative ground, and replace the light bulbs.) I like to put a 40 amp fuse, or fuse link, in the wire going to the Battery from the amp gauge to protect things if connections are made wrong when jumping, or the alt fails. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
