If it is not equipped with a blade now, don't do it. They are not often equipped with a PTO, but they can be. It will be a real chore to install one. They do not run a mower satisfactorily. they tear up the ground on corners and mash the grass/weeds so profoundly ahead of the mower that the mower will not cut them leaving radical regrowth in the track paths. Pulling is its strong suit. Pulling stuck machines out is easy for the tracked T6. It has an M Farmall motor in it if it is old, or a 6 cylinder if newer. Undercarrage condition is the deal breaker. Have someone local (with expertise) look at the tracks, rails, sprockets, and bogies. Way too much money will be spent on a worn out set of tracks to justify the purchase. It will use radical amounts of gasoline. Steering clutches, track brakes, and master clutch are also check points. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
