Re: Fuel filter in sediment bowl on H?
Posted by Janicholson on December 26, 2014 at 19:24:00 from (74.60.94.18):
In Reply to: Fuel filter in sediment bowl on H? posted by obH on December 26, 2014 at 17:40:20:
The use of a filter is usually an indication of rusty or contaminated tank. In a gravity fed system there is little pressure to push fuel through a conventional filter. NAPA and others sell filter (self contained in line style) that are designed for gravity systems. Cleaning is best, followed by an appropriate filter if needed. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
