Re: Fuel filter in sediment bowl on H?
Posted by Dean Olson on December 27, 2014 at 10:03:32 from (107.129.21.194):
In Reply to: Fuel filter in sediment bowl on H? posted by obH on December 26, 2014 at 17:40:20:
third party image
third party image
I eliminate the sediment bowl all together and replace with the
pictured assembly. This allows a full 3/8" opening into the bottom
of the tank. big chunks fall into the dirt leg and are easily cleaned
by removing the cap. 3/8" ball valve allows for positive shut off.
I use a filter from NAPA Works perfect.
  Upload Photo  Select Gallery Photo  Attach Serial No List
