There really isn't any bypass wire on this tractor but rather the resistance wire is bypassed. The power comes from the key switch through the multi connecter under the dash near the voltage regulator. The next piece of wire is the resistor which is crimped into the same connector at the solenoid with the wire that goes to the coil. The by pass is the I terminal on the solenoid. When the starter is engaged the I terminal is energized internally from the battery cable contact which provides cranking voltage to coil leaving equal voltage on each end of the resistance wire. When the solenoid is de-energized the current again comes through the key switch through the resistance wire to the coil.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
