Posted by Dieseltech on December 28, 2014 at 21:39:48 from (199.16.223.2):
In Reply to: Re: 1086 Boost Levels posted by TD2593 on December 28, 2014 at 18:02:57:
There is probably a wastegate model that might work by now. IH Blue Ribbon service book has the intake and exhaust pressures listed with the pump specs, most exhaust pressures run about 2 PSI less than the intake for a good match. For best results an intercooler should be used no matter what turbo is used above 15 PSI. Compressor outlet temps really start to climb, even 190 degree water temp will cool the air back down. Hugh McInnes Turbochargers book shows how the air outlet can be 400 degrees or more as the pressure rises.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
