Re: New to me Hydro 70 questions?
Posted by mkirsch on December 29, 2014 at 10:46:08 from (72.45.143.81):
In Reply to: New to me Hydro 70 questions? posted by tractorsam on December 29, 2014 at 05:54:33:
I may be confused on this but if the power steering and the hydro work, the problem with your 3pt isn't the pump. Have you tried moving the draft control lever to "position?" If it is set to heavy draft, I think the hitch will drop in an attempt to create maximum draft, and will not come up with the position control lever.
The AMP light is trying to tell you that there is something wrong with the charging system. Alternator, regulator, or wiring.
