I would lean toward the idle jet being plugged or damaged. If venturi was removable and installed upside down the opposite symptom develops. They will idle fine as venturi has no effect at idle because idle ports are above throttle plate. I am not familiar with a cub carburetor but if throttle place was installed backwards it might also close off the idle ports in the throat.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
