Re: better picture of M hydra;ics
Posted by Cory Schmidt on December 29, 2014 at 13:33:03 from (64.246.253.39):
In Reply to: better picture of M hydra;ics posted by rick deere on December 29, 2014 at 12:16:31:
First off I see you have 2 valves. The one on the tractor(the lift all) is pinned to the frame to provide continual pressure to the second(tree). If the fluid is not being used (making implement move) the fluid bypasses the valve and goes back via return. The return on the 2nd valve is directed though the fill hole. As the fluid falls back in it pushes air out(oil is pushed back out with air). To fix route return to drain at bottom of tractor. This forces the return oil to push oil(that pushes air up) and the air leaves via the vent (that is plugged on cap) or open cap.
This post was edited by Cory Schmidt at 13:52:45 12/29/14 2 times.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
