Re: better picture of M hydra;ics
Posted by Janicholson on December 29, 2014 at 15:18:19 from (74.60.94.18):
In Reply to: Re: better picture of M hydra;ics posted by rick deere on December 29, 2014 at 12:18:04:
The bottom of the valve in the picture is connected to the fill pipe riser with iron pipe. That pipe is the return. Disconnecting it is necessary to redirect the return flow to the bottom of the reservoir. When disconnected, the valve becomes unmounted, and will require fabrication of brackets to hold it in place. A simple solution to the problem is to put a metal disc and gasket on the existing cap. As long as double acting cylinders (two hoses) are used, the level will not change much, and fluid will not leak out. If single acting cylinders are used, the cap must be vented. in which case the best is to reroute the return to the bottom, and make brackets. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
