Re: better picture of M hydra;ics
Posted by Cory Schmidt on December 29, 2014 at 15:18:45 from (64.246.253.39):
In Reply to: better picture of M hydra;ics posted by rick deere on December 29, 2014 at 14:51:51:
check that the cap and plug(try pipe plug not just a bolt) are tight. If its running out even with the cap on it might just be loose( or worse a busted thread) The strap on the frame holds the "lift-all" valve control to provide pressure to the other valve(that gives two way pressure), this set up is fine. With out it you would have to hold it(lift-all) while running the other one.
This post was edited by Cory Schmidt at 15:24:19 12/29/14 2 times.
