Slater gave you the answers you need. But take that fixed rod off when not using the two way valve and then no oil will be flowing through that tree all the time. KEEP BLEEDER VALVE CLOSED WHEN USING TWO WAY. To use it on single action cyl, then you lock two way and use belly pump outlet. Do not use the two way hoses on a one way as the bleeder has to be open and then you will have oil running all over. So, if you use it on one way you will need to add a proper lever on belly pump.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
