Re: New to me Hydro 70 questions?
Posted by tractorsam on December 29, 2014 at 17:39:07 from (96.30.183.40):
In Reply to: Re: New to me Hydro 70 questions? posted by pete 23 on December 29, 2014 at 16:59:46:
Sounds good. I am seeing the 'action control' section at the front of the position control. Where is the action control device? Where is the unloading valve for the draft control located and can it be disassembled or otherwise checked? I'm assuming the hitch pump has the smaller steel line coming off it (not the larger rubber one)? If I disconnect the loop for the loader valve and insert a valve I assume I need to be careful that I don't exceed max system pressure when I close (or partially close) the valve? What is the max system pressure? Thank you and sorry for all the questions. Sam
  Upload Photo  Select Gallery Photo  Attach Serial No List
