I set up an M one time with an open center spool and had the same issue. The problem is that when the fluid hits the "T" half goes down and half wants to go up.
What I did was put the return where the cap was and the filler/vent cap on the "T" part. Then the returning fluid shoots straight down. Problem solved.
You could also plumb the return to the drain plug as suggested. I don't like that idea because I think it stirs up the inevitable trash that collects at the bottom.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
