Re: 1943 M engine
Posted by DeltaRed on December 29, 2014 at 18:54:34 from (65.100.146.228):
In Reply to: 1943 M engine posted by farmboy48 on December 29, 2014 at 18:18:28:
As was said,look at the casting numbers on the
block to determine year. I would agree it is a
replacement power unit engine.OR....it could be
original engine with a M/W dip stick.But I kind of
doubt it from your description.About adding a
'mag' pump for live loader hydralics,DONT.That
pump does not have sufficent pressure and volume
to run that loader.If you want live hydralics for
the loader,hang the pto pump off the front frame
rail and chain drive it from the crankshaft.
Common practice.And a WHOLE LOT cheaper than a
(new) mag pump.Last one I priced was $1100.00!
  Upload Photo  Select Gallery Photo  Attach Serial No List
