First simple thing to check is to remove the hex cap on the bolster front. Check the bearing on the front of the worm shaft. See if the bearing retaining nut is contacting the inside of cap. If that's not a problem drop the vertical shaft and check the thrust bearing on the shaft that supports the load. With it out you can check all steering parts in bolster. To remove shaft the gear on top needs the nut off and lower bolster removed. Remove the key. That was from when a cultivator shift bracket was used and they left the key. Up and down movement in vertical shaft is normal. Of coarse jack and block tractor up before starting. May take considerable force to get the shaft down out of the sector gear. I like to leave the lower bolster and tires on until the shaft exits the gear. Also easy to hold the bolt heads from spinning when removing the lower bolster after it drops a few inches.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
