Re: Frustrated with cub in So. Indiana
Posted by leon on December 30, 2014 at 04:05:58 from (173.24.134.58):
In Reply to: Frustrated with cub in So. Indiana posted by Mpriar on December 29, 2014 at 17:32:35:
I burn the paper off a twister seal, wipe clean the very, very small, soft, flexible wire inside and use that to clean out carburetor passages. Now I need to devise a non-messy way to set my gallon of carb cleaner inside my vibratory cleaner intended for cleaning brass cartridge cases. Agree with others, longer soaking is needed. Sometimes there are rubber-like gaskets that you want to keep out of the cleaner though because they may expand. Then sometimes there are gaskets, mostly cork-like, that will shrink if let dry out. While soaking the carburetor I keep them in a shallow little pan of gasoline or diesel fuel - in a safe place of course. The trick is knowing which gasket has which characteristic! That's what makes this hobby fun!
  Upload Photo  Select Gallery Photo  Attach Serial No List
