Re: Farmall B Zenith Carb Adjustment
Posted by Dean Olson on December 30, 2014 at 05:50:04 from (107.77.80.17):
In Reply to: Farmall B Zenith Carb Adjustment posted by calcubman on December 30, 2014 at 05:39:33:
That's a classic fuel starvation symptom.
Back track to the fuel tank, sediment bowl,filter, filter in carb inlet, gas cap vent, run a small wire through all the ports in carb. I use torch tip cleaning tool with multiple wire sizes.
I've read on these forums about leaking manifolds, gasket or cracked. That creates a low vacuum issue. I've never had that happen. It's usually some tiny piece of debri I missed in the fuel delivery system.
It's frustrating, having been there and done that more than once. In my case I start over and check everything, again, till I find what I missed.
  Upload Photo  Select Gallery Photo  Attach Serial No List
