Re: Farmall B Zenith Carb Adjustment
Posted by gene bender on December 30, 2014 at 07:00:38 from (67.55.226.121):
In Reply to: Farmall B Zenith Carb Adjustment posted by calcubman on December 30, 2014 at 05:39:33:
Does the gasket between the two halves fit good and is the joint between the carb and manifold clead and a new gasket. You are sucking air someplace causing it to run too lean. If the fuel line was plugged pulling the choke would not help
  Upload Photo  Select Gallery Photo  Attach Serial No List
