Re: Farmall B Zenith Carb Adjustment
Posted by old on December 30, 2014 at 08:38:50 from (209.86.226.32):
In Reply to: Farmall B Zenith Carb Adjustment posted by calcubman on December 30, 2014 at 05:39:33:
If I remember right those carbs do not have an adjustable main jet and your is most likely still clogged up. The screw your adjusting is the idle jet so yes it will do nothing above an idle.
When you clean a carb you need to use a small wire to poke out the passage ways my self I use a torch tip cleaner tool to do that. You also need to use spray carb cleaner and air to make sure every passageway is clear of dirt and rust. You may get by by removing the plug over the main jet and then poking it out with a small wire. Have the gas turned on when you do that so any dirt.rust you loosen up will be washed out and to the ground
  Upload Photo  Select Gallery Photo  Attach Serial No List
