Re: Farmall M Steering Lock-up Issue
Posted by wayne in MN on December 30, 2014 at 09:20:33 from (97.92.1.19):
In Reply to: Farmall M Steering Lock-up Issue posted by johnb5345 on December 29, 2014 at 22:01:26:
The ball bearing at the bottom of the bolster shaft is a likely suspect. The square (likely 1/2 moon or Woodruff) key is from the cultivator steering arm used with check-row planted corn. Take a diagonal cutters & grab one end of the key and pry it out. I ground off the side of my diagonal cutters so it would lay flat on a shaft to get a good bite on any key.
  Upload Photo  Select Gallery Photo  Attach Serial No List
