The 10SI is the only type of alternator listed for the Hydro 70 tractor.
A bad diode trio may cause symptoms like you are describing. If the diode trio does not provide power internally to the regulator the alternator may still continue to provide charging voltage. The filed coil in the rotor will still continue to receive power through the light bulb but the light will remain on and the output amps of the alternator will be reduced.
More likely your problem is poor connections either internally or external to the alternator.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
