You might check your meter on your car with it at rest and with it running.
A reading 14 volts from a standard automotive battery at rest is simply not possible - fundamental lead/acid electrochemistry precludes it.
However a voltage reading of 18 volts while charging IS possible. I ran into it once on a CIH 9280 with a bad (shorted) voltage regulator. It seriously overloaded the alternator which overheated and quit working after about 30 minutes. It also raised h*ll with the battery - it boiled acid out until the alternator quit.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
