Re: converting M from 6 volt to 12 volt
Posted by Notjustair on December 31, 2014 at 07:25:07 from (70.195.64.163):
In Reply to: converting M from 6 volt to 12 volt posted by Farmall98 on December 30, 2014 at 20:13:04:
I have found that a Delco (10si) works well under the hood of
the M and has just be right mountings. It has been mulled over
a million times - search the archives in modern view you won't
ever regret putting an alternator on it. Unless you cut the hood,
of course. Then we will all shun you.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
