Re: Differential filler plug tool
Posted by Haas on January 10, 2001 at 06:19:39 from (129.37.117.114):
In Reply to: Differential filler plug tool posted by Neal (TX) on January 09, 2001 at 21:33:50:
Neal, the H has an oil bath air cleaner and the metal screens are not removable. You only need to clean the oil cup and put engine oil to the indicated level. Check the screens to make sure they are clean. If they need cleaning, take the air cleaner off and soak it in kerosine or mineral spirits. Don't try to remove the screens from the can. You can get the oil filter at Tractor Supply, your Case/IH dealer or NAPA.
Post A Followup
: Re: Re: Differential filler plug tool
