Re: Farmall C ..help with oil change and amounts.
Posted by Haas on January 10, 2001 at 06:47:03 from (129.37.117.114):
In Reply to: Farmall C ..help with oil change and amounts. posted by Trueby on January 09, 2001 at 15:44:25:
Here is what the manual says:
Cooling system 13 quarts
Crankcase 5 quarts
Transmission 5 gallons
Touch control(hydraulics) 6 3/4 pints
Fill the touch control to the bottom of the fill hole with the rockshaft arms in the rear position. You will need to operate them back and forth several times to get the air out of the system. Then recheck with the arms in the rear position and refill to the bottom of the hole. Use Hytran fluid in the touch control, 30 wt in the engine (Unless the weather is really cold, then use a lighter weight, but be sure to change on warmer weather) and 90W gear oil in the tranny.
Post A Followup
: Re: Re: Farmall C ..help with oil change and amounts.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
