Re: converting M from 6 volt to 12 volt
Posted by farmboy48 on December 31, 2014 at 22:34:27 from (208.107.15.166):
In Reply to: converting M from 6 volt to 12 volt posted by Janicholson on December 31, 2014 at 17:58:09:
[quote="Janicholson"](quoted from post at 18:58:09 12/31/14) If you are using a digital meter, it might be reading transient voltages. Turn on the lights to see if they dim and brighten. If steady it is likely the meter. Steady amp flow is also an indicator of normal operation. Jim[/quote]
Thanks Jim, it is digital meter, I will check again tomorrow with a couple other meters. This was the cheap one. No lights on it yet, will try a spotlight with alligator clips tomorrow too. Ammeter is steady, no bounce. Alternator came off a junked 82 Mazda pickup that caught my eye on shelf a couple days ago, so figured give it a try.
Dick ND
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
