Re: Farmall H oil use
Posted by riverbend on January 01, 2015 at 04:32:38 from (74.37.50.221):
In Reply to: Farmall H oil use posted by johnmcc on December 30, 2014 at 08:02:31:
Just to be sure we are on the same page, the motor
is blowing liquid oil the exhaust when it is
warmed up ? Or is it smoking ?
If it is liquid, it would have to be coming from
the exhaust guides. Unless the oil is really
running out it should evaporate and smoke when the
manifold is hot. You can tell if it is just wet
soot by letting the spots dry.
How much oil does the engine use ? What was the
difference between wet and dry compression tests ?
What is coming out the breather on the side of the
engine ?
Greg
  Upload Photo  Select Gallery Photo  Attach Serial No List
