Posted by Janicholson on January 01, 2015 at 10:26:38 from (74.60.94.18):
In Reply to: My First IHC. posted by lfure on January 01, 2015 at 07:42:45:
It will work perfectly by switching the hoses. Be careful toset the bucket on a surface and remove all internal pressure before disconnecting the hoses. If the lift cylinders are one way, the valves must be switched from one way to two way on the one now connected to the lift, and from two way to one way on the valve now connected to the bucket. This is accomplished very easily by rotating a switch on the valve (opposite the lever end). This switch consists of a projection with 2 flat surfaces, and a roll pin that tucks under a flat metal guide. IIRC there is a S on the valve body near the end of the metal bracket for Single, and a D on the other end for Double. It should turn easily, so be gentle with it and don't bend the pins. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
